bendel avatar image
bendel asked
MultiPlus II cable length of Ac Sensor
Hi. I have a Building about 30 m away from the Place i Need to install the ac Sensor. Since all the cableing and the MultiPlus Shall be installed in the Building 35 m away i Need a possibility to transmitt The Signal of the ca Converter about 35m can you give Advanced what can be done?
Best regards Norbert
Multiplus-II
Rob Duthie avatar image
Rob Duthie answered ·
Hi
You can use the DTK electronics wireless units that convert RS485 to USB to link to the CCGX
or raspi units.
I used these models from a Ebay supplier DRF2658C USB unit and the DRF2659C RS485 unit
all worked OK. No issues as i have AC sensor in my switch board some distance away.
Is this what you are after?
Regards
Rob D
NZ
Hi @Bendel
The 'AC Current sensor' is only for a connection close-by, for longer distances you'll need a 'grid meter', this can be connected by cable or wireless
https://www.victronenergy.com/accessories/energy-meter
You'll need a Venus device also with this, but I assume you already have one (planned).
bendel avatar image bendel commented ·
Thank you, why do i Need a Venus device ?
Just for visualiazation or is it needed for Communication Grid Meter with MultiPlus II
Have a Nice day.
bendel avatar image bendel bendel commented ·
In case i Bus a MultiPlus II GX is the Venus device needed for Communication bewtwwen the Grid Meter and the MultiPlus Ii GX.
Thank you
Sorry i mean: In case i buy .....
bendel avatar image
bendel answered ·
Hi Daniel and Rob,
Thank you Both for the
answers. I think i Daniels Solution,is covering my Problem : the Ac Sensor is too gar away from my MultiPlus II.
Robś Solution is covering from My understanding an Other problem :the additional overview Screen (CCGX) is too gar away from the MultiPlus II.
Thank you for your answers!
Have a nice day.
Regards Norbert
