I can see the Blue Smart in the app until it turns off. It shows the correct voltage, but 0 A current flow.
And I can repeat the process.
I connected both the battery as well as the AC input.
The app displayed the the beginning of charging process (absorbtion) with about 25,5 V and 0 Ampere current. That surprised me.
I repeated the process 5 times with the same result: After about 2-3 minutes the charger turned completely off.
best regards Steffen
Please check if the fuse to the battery is intact, thus the battery well connected to the charger.
Ask an electrician if your not sure.
If all is well, then the unit might be broken if so, please contact the supplier of the unit for a replacement.
I connected both the battery and die AC input. The app displayed the first phase of charging with about 25,5 V voltage and 0 A current. The battery monitor (also Victron)displayed the same voltage. So I thought that all is ok.
If I disconnected and one more connected the AC the same procedure started. I tried it about 5 times with the same result.
Tomorrow I'm going to call the company if they ca help me.
Best regards Steffen
Hi, Daniel,
I connected an 24V/100Ah AGM-battery-Pack. I use it for a trolling motor on my sailboat. The app displayes the correct voltage of 25.5 Volt, but 0 Ampere current. After about 3 minutes the app lost the connection because the device turned off.
What exactly have you connected (battery? AC input? both?) and what is displaying on the app?
9 People are following this question.
