Is it possible to charge the Lithium Leisure battery and the starter battery with this and if so how would i change the charging requirements.
You cannot charge with two different profiles at the same time, as the outputs are non-isolated. Assuming your start battery and your leisure bank share a common negative return path (ie, chassis ground), then I'd suggest just setting the charger to a Lithium profile suitable for your leisure bank. Your starter battery should only be needing a bare trickle in any case, it will take a lithium charge profile just fine.
Blue Smart IP22 Product Page
Blue Smart IP22 230v datasheet
Blue Smart IP22 120v datasheet
Blue Smart 120v manual download
Did You Know? - use the blue smart as a power supply (video link)
History and Settings for Blue Smart Chargers in Victron Connect (video link)
40 People are following this question.
