John_Klusa avatar image
Hub-4 upload problem
I'm working with Multiplus Compact 48/50/6 and I need to load assistant Hub-4 instead of ESS. Problem appears in VEConfig, while uploading the Hub-4 assistant into device (Error showed below). I've already tried to upload an older firmware to Multiplus, but the problem remains the same. I've also tried an older version of the Hub-4 assistant.
Do you have any tips or advice? Thank you for any comment.
VEConfigure 3
John_Klusa answered ·
Hi mvader, thank you for your response. The point is that I'd like to control the inverter via TCP/IP externally. ESS contains e.g. ramp response of power when step is required. I was told that Hub-4 doesn't have this function. I would like to benefit the fastest response possible. John
Share
Hi John, sorry for the slow reply! Peculiar for “community” type support I’m afraid.Why not use ESS instead? We stopped supporting Hub4 several years ago.
Share
