bitkid avatar image
bitkid asked
Getting unexpected API results via Note-Red call
Hello... I new to Node-Red but after watching all the tutorials and with some prior programming knowledge, I am getting the hang of it.
I need a little help with VRM API call
I have added VRM API node to Node-Red and trying to pull historical data, but I am getting results that don't match with the values in VRM.... not sure what I am doing wrong, maybe someone can point me on the right path. My final goal is to pull how much kWh were injected to the grid and how many were consumed from the grid in specific timeframe to implement some logic around it... but none of the values makes sense to me.
Example:
VRM values for Yesterday (3/30 00:00 till 3/31 00:00)
Node config:
Result in Node-Red debug:
My consumption in VRM is 6.1 kWh for yesterday. I get 236.32...? as result. What gives?
https://vrm.victronenergy.com/installation/XXXXX/dashboard
Using XXXXX from URL for VRM side id in the API node
VRMNode-REDapi
