engabdiazizxidig avatar image
engabdiazizxidig asked
Error code: #82 - PV Input shutdown
Hello everyone,
I had encountered a problem of Error code: #82 - PV Input shutdown of two charge controllers with multiplus-II 8kVA inverter with 2 of 4.4kWh batteries that is 8.8kWh battery bank.
The alarm comes, when battery reaches 100% SOS, I updated the firmware of each component; I have also installed stabilizer to stabilize the grid voltage.
manual error
nickdb avatar image
nickdb answered ·
From the docs:
When these errors show, the PV Input is internally shorted in order to protect the battery from over-charging.
Prior to any other trouble shooting, make sure to update to the latest firmware version.
Possible reasons for this error to occur:
  • The Battery voltage (12/24/36/48V) is set incorrectly. Use VictronConnect to set the right Battery Voltage.
  • There is another device connected to the battery, which is configured to a higher voltage. For example a MultiPlus, configured to equalise at 17 Volts, while in the MPPT this is not configured.
Error recovery:
  • Error 38 and Errors 84 to 87: First disconnect the solar panels and disconnect the battery. Wait for 3 minutes, then reconnect the battery first and next the panels.
  • Error 39: The charger will automatically resume operation once the battery voltage drops below its maximum voltage setting (normally Equalisation or Absorption voltages). It can also takes a minute to reset the fault.
  • Errors 80 to 83: First disconnect the solar panels and disconnect the battery, then follow the reset procedure described here.
If the error persists the charge controller is probably faulty.
