Hi There
I forgot to save mine VRM token , i am out for ever ?
please help me with reset or work arround
thx Hans
Thx for the quick response, those are the Victron connect tokens if i am correct , but i need the token i can use in de VRM API node
is that the same ?
Tested mine, worked fine with installation data.
thx but is the token field wish gives a error
I did it again now from scratch and setup the API node connection as new, worked fine.
{85e89b13-43e5-4fa9-830f-8d2fa107605a} |
is the token what it shout look like ?
39 People are following this question.
