reinder avatar image
reinder asked
ESP DC breaker panel - What are the individual breaker values & connecting backlight.
On the panel that I purchased the individual breaker amperage is not clearly marked on the panel nor is it possible to see it on the breakers itself.
Can I assume that the amperages are as stated below from top to bottom?
In order for the system panel to control the backlight, where should I put the negative wire, as it is not clear on the diagram below nor on the panel itself?
dc system
