I am using MQTT on a Quattro 3 phase system with solar and lithium batteries for some reporting and automation.
I capture N/c0619ab616b2/grid/30/Ac/L1/Voltage, L2 and L3 to monitor the input voltage. I noted that when the chargers are working, the voltage measurements show quite high surgers/spikes. See chart. I wonder where such voltage is measured internally if before or after the input filter because it makes the inverter appearing quite bad. Any idea?
