Hi Allan,
You can only monitor voltage or temperature as the second function, not both at the same time. You can use a Smart Battery Sense for the aux battery if you want. Get a blue one (longer range Bluetooth).
https://www.victronenergy.com/accessories/smart-battery-sense
10 People are following this question.
