hedgecrawler avatar image
hedgecrawler asked
problems connecting with ve bus and phoenix 24/2000
I am having mixed results being able to configure victron phoenix 24/2000 using mk 3 usb device.
the inverters were previously part of a 3 phase system and i hope to reuse them as standalone single phase units.
inverter 1 reconfigured fine and is currently working.
inverter 2 does not display eigher in ve configure or ve bus quick configure
inverter 3 displays in the ve bus quick configure but remains grey (in the image) and will not display in ve configure. does display that it is 3 phase and i assume that it is looking for other units but finds none as need it to be standalone.
the inverters are all the same age the mk3 to usb works as you can see from inverter 1, and also used other compatible kit in the past.
is there something im doing wrong here? what else can i do to reset to defaults.
thanks for any help
VEConfigure 3
