boreddesigns avatar image
boreddesigns asked
Mppt choice for currently installed panels and battery
Hi, I'm new to this forum and would like to replace my current Luxpower 5kw inverter with a Victron multiplus 2. I currently have 7 x 460w JA solar panels on one string in series and a 48v 11.2kw battery. I have roof space to add another string of panels, easy facing, at a later stage. The recommended charging amps for the battery is between 30-50amps.
With my current setup, which would be the most cost affective and logical blue solar mppt to go for? If I added another 460w ja panels, could I run 4S3P to a 250/60 mppt?
I'm new to low voltage mppts, so any help would be appreciated.
MPPT SmartSolarSolar Panel
nickdb avatar image
nickdb answered ·
Go to the solar charger product page, there is a link to the mppt calculator which is what you need to use.
MPPT product page
VictronConnect manual
PWM or MPPT
MPPT calculator
MPPT codes
