2 - 24/5000 inverters, 16 - 24 volts battelborn batteries,
If one device is switched off in a split phase configuration, the other will go into error, as it expects to be able to read data from the other device to maintain synchronisation.
When inverters tripped, led lights are showing float error.
Inverters are tripping when rj45 is connected to cerbo.
84 People are following this question.
