matthewmurphy avatar image
matthewmurphy asked
Can the Multiplus 2kVA 120 be mounted on its side?
Hello! Currently working on my camper van electrical system. Due to the battery being too big I need to have the multiplus mounted on its side on the ground. Can I do this? I really have no other option as far as placement within my allotted space for where the electrical components go. Any help is great! Thanks
victron
Jason - UK avatar image
Jason - UK answered ·
@Matthew.Murphy If you are going to mount it on its side, you need to be aware of the impact to passive cooling lost by not being in the vertical orientation. A simple solution is to have forced continuous ventilation one end of the unit otherwise you may find a reduced performance form the unit
