Tony avatar image
Tony asked
Cerbo GX with no HDMI output
I have tried connecting several monitors with HDMI inputs to to my Cerbo GX, I swapped the HDMI cables but still no sign of a signal. Has anyone had a similar issue?
Other than the HDMI output everything else appears to be functioning fine on the Cerbo.
cerbo gxhdmi
ejrossouw avatar image
ejrossouw answered ·
@Tony If you search the forum you will find a number of threads on the topic. It is designed for the GX Touch devices and unsupported on anything else. The cable carries touch screen input signals, which may not be compatible with your tv etc. There are mixed results out there so maybe do a quick search on cerbo hdmi ;)
Tony avatar image
Tony answered ·
I have read several threads on here and the only thing you loose is the touch screen functions. The HDMI should output the video signal irrespective of lack of input. I appreciate what you are saying but there should still be a video output. I have checked the aspect ratio and resolution and these are set up correctly.
ejrossouw avatar image ejrossouw commented ·
I have never tried this personally, although have at least one customer who has a TV connected to his. Have you tried it on another TV or PC monitor? Otherwise, definitely not my area of expertise and maybe the modifications section is best for this thread.
nickdb avatar image
nickdb answered ·
Moved the original post to modifications. Will close the duplicate.
Alex Pescaru avatar image
Alex Pescaru answered ·
If you just connect it, on the fly, then it doesn't work.
I have the impression that at boot time the system checks for monitor presence and acts accordingly. Or vice-versa, I don't know...
I've also had this problem with a 7" display and after I rebooted the Cerbo, after a while, after boot, the monitor started to work.
The monitor is this one: https://www.aliexpress.com/item/1005003539330174.html
Tony avatar image
Tony answered ·
Thanks for your help, I followed your instructions and it's working now working.
