Daniele avatar image
Daniele asked
Multiplus-II GX every 4 minutes drops 3 packets.
Dears,
Can you help me fixing packet loss? The issue occurs on LAN and WiFi. I tried changing LAN cable, router, GX version upgrade, but issue still occurs. Seems if I shut down Multiplus-II GX after power up the issue does not occur for the first 24 hours. Sometimes unplugging cable and reconnecting helps but not always. It's always the same issue -- every 4 minutes, 3 packets drop. This is causing remote console to disconnect and also disrupt any updates running.
Thank you
Daniele
multplus 2 gx
@Daniele
The only thing I can think of off the top of my head is the inverter is running hot, so the GX is affected which influences stability.
Daniele avatar image Daniele Alexandra ♦ commented ·
Thank you Alexandra for your response but temperature is not the cause. Current invertor (3.2kW) load is 200W and temperature in the room is 5-10C and it's very consistent. Every 4 minutes 3 packets lost.
e.g.
Ping statistics for 192.168.XX.XX:
Packets: Sent = 159, Received = 156, Lost = 3 (1% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 18ms, Average = 1ms
@Daniele
I've fixed your user profile to prevent your email address appearing in posts
Jason - UK avatar image
Jason - UK answered ·
@Daniele
Is your network cable routed adjacent to any AC cables? if so, try and separate by 50mm. Unlikely the issue but worth checking.
A few other questions,
Do you have a fridge or freezer connected to your AC loads?
Is the installation off-grid on grid connected?
Can you provide a photo of the installed Multiplus?
