Troy avatar image
Troy asked
MPPT RS 450
Good morning
I am still new here so please be kind lol
Step by step please
So at the moment
I have an MPPT RS 450
I have seen some confusion around this MPPT
However
I have 4 x 405 w Panels on one string
Now the question is
I have also 3 x 370 w panels
Can I throw them onto the same string without effecting the 405's in anyway
Or Can I just take the 3 x 370 w panels through my MPPT 150/100 Directly into the Lynx Distributor to the battery along side the 405 panels
Thanks everybody
Troy
It would be a good idea someone who knows about this machine
If anyone has a good plan also or wiring diagram to also attach my 400w Windturbine would be welcome also
MPPT Controllers
Alex Pescaru avatar image
Alex Pescaru answered ·
If the VOC of those 3 panels are 50+V, then you can try putting them on the other tracker of the RS.
Although it can be on the lower level of the MPPT starting voltage.
Better with the 150/100, but you need to have some coordination between those two MPPTs, the 450 and the 150.
Otherwise, although you can put them in series with the other 4, those two types of panels, having different voltages and currents, is not recommended. The RS will have a hard time to find the correct MPP, because your/the resulting IV curve will have several maximums.
Read here: https://solarpanelsvenue.com/mixing-solar-panels/
