I'm curious about the recharging rate of a\my MP II 12v 3000 120..
In the "Charging section"... what determines how fast or slow it recharges. Is it adjustable..?
this will depend on how the sysyem was setup by your installer, and Yes it can be adjusted, but discuss this with your installer
It depends.
Current limits - AC IN, DC charge limit.
Inverter load, available PV, temperature.
Inaccurate SOC - expecting it to be charging but it is actually quite full.
Inverter mode - yours is in sustain, so it is going to hold the battery at that voltage so it won't do much more. Check your settings, and any additional ones you may have made for solar priority.
As @nickdb said, there's a charge limit setting. AC in will override this if the battery charge rate is higher than is available from AC. The 30A you mention applies to AC in, so convert this from 120 to battery voltage to get a better idea, but unless you set AC in very low, it's not likely to be a restriction.
106 People are following this question.
