What is the maximum pv input voltage for victron multiplus II 48/5kva?
I'll be running a 48 volt system.
Thanks
Thanks
The multiplus does not directly connect to PV, it will share the DC bus with an appropriately sized mppt or two - use the calculator to size it properly.
if you want an all in one youll need somthing like the easysolar 2 gx
https://www.victronenergy.nl/inverter-charger-mppt/easysolar-ii-gx
104 People are following this question.
