Tomas Faal Petersson avatar image
Tomas Faal Petersson asked
Phoenix MultiPlus: Erratic charging of Macbook
Hi, I have a Phoenix MultiPlus from around 2009 set up in my home office like an UPS.
I have all my equipment connected to its output, like monitor, router, macbook.
Everything works fine except the macbook, it won't charge. It blips on and off charging every couple of seconds. If I connect the macbook charger directly to mains it works fine.
When mains is present the MultiPlus just passes it thru, right? So there should be no difference connecting to the MultiPlus or to mains directly?
Any idea what could be causing this? Is my MultiPlus faulty?
Regards, Tomas
Multiplus-II
