my multiples 2 is charging the pylon tech battery, but won't allow battery to discharge.
@larrycampion Absolutely nothing to work with so can you please elaborate on the type of setup e.g. off-grid or ESS, screenshots of ESS settings, diagram showing location of energy meters etc. Another obvious one is the mode that is set to keep the batteries charge.
106 People are following this question.
