holzbein avatar image
holzbein asked
Victrom MP2 BMS-minus seperate
Hi!
I use Seplos BMS V3 and V2.
With V2, the electronic cut off PLUS. With V3 it looks like the BMS electronic cuts off MINUS. (And I want to change from V2 to V3, so both accu packs are the same)
I heard, for victron you have to seperate PLUS, otherwise a possible data com-line would get troubles when main MINUS is seperated.
I also heard, it doesn't matter with new victron products.
What is the correct answer? How can I determine if I use an old or new victron MP2?
Thank you!
viktron mp2seplos
