jwfrary avatar image
jwfrary asked
Victron multiplus charging settings when in parallel
Hi a quick one hopefully. I'm just trying to figure out when we have two parallel multis 24/3000/70/50 what the charging rate will be doing respectively
We will be hooked up to a 560ah agm battery bank so the required maximum charge rate will be in the region of 100amps ish out of an available 140 between the two. Should I just be leaving them on the default 75percent setting so that's 105amp max charging. Or am I interpreting the manual incorrectly?
Thanks
battery charging
Mark avatar image
Mark answered ·
When operating with multiple units in a parallel configuration, the charger settings in the Master unit will used by the other units in the system.
With the max charge current setting, just remember that whatever is entered into the master unit will be multiplied but the number of units in the system.
https://www.victronenergy.com/live/ve.bus:manual_parallel_and_three_phase_systems
jwfrary answered ·
Thanks for clarifying
