anderson avatar image
anderson asked
Can i change the absortion voltage config below the 48V in victron Multiplus II 48V|3000VA|35A?
I am using a Multiplus II inverter and a battery that i need to charge until 45,39V. The inverter operation is 33-66V. It´s possible to configure the absortion voltage below the 48V? In the VE Config the range informed is 48-64V. Is there anything else I can do?
Multiplus-II
