Duncan avatar image
Duncan asked
12v to 24v
Hi
I am changing my system from 3 panels and 12 v to 6 Panels 24v. I have a MPPT 150/60- MC4 charge controller. I will have to change the settings? But I don’t have the ability or expertise to do this via computer. Can I use one of the factory preset mode to change the setting manually? I have 2 Varta LFD 230 batteries.
Hope someone can help.
MPPT Controllers
adev avatar image
adev answered ·
I believe when you first connect the controller to the new battery bank (do this BEFORE you connect the PV array) it detects the battery voltage and configures the settings appropriately.
Try reading through the manual for your charger, which should be available in PDF form on the victron website.
