andrew-w avatar image
andrew-w asked
Direct connection to immersion.
I have reached my limit on grid tied solar but want to implement more solar by using off grid applications. I have quite a high and consistent usage of hot water so would like to implement a pre heater tank to feed my existing boilers with hot or warm water. What are my options for connecting a solar array to an immersion directly, via an MPPT? Many thanks!
MPPT ControllersHot Water Diversion
atebee avatar image
atebee answered ·
Lots of options. What is your setup in terms of inverter, batteries, solar?
Also a bit more detail on your existing hot water setup would help.
andrew-w avatar image andrew-w commented ·
Thank you. I have a grid tied system that is fully utilised, I want to add more but can't get permission from my network. So I want a stand alone, off grid, system to pre heat water to supply an existing boiler. The boiler is 500 litre and part of an important installation and I don't want to interfere with it at all. So I want to add a new cylinder with an immersion connected to an off grid array to feed the existing boiler with hot or warm water. Thanks again!
atebee avatar image atebee andrew-w commented ·
A solar thermal setup might be a better option than PV in this case.
With a battery and suitably sized inverter you could intermittently dump power into an immersion element based on some simple logic i.e. if the battery is 90% full then turn on the load until say your down to 10%. That can probably be done via an assistant on a Multiplus/Quattro. Or Node-Red automation on a CerboGX.
An air to water heat pump would be a more energy efficient solution to heat your tank but more costly. Air to water in a DWH scenario is COP of ~3 so you would be getting 3kWH hot water from 1kWH PV. A small unit would also draw less power than an immersion element. Only issue is the compressors have quite high startup loads which might not work well with a small inverter.
andrew-w avatar image andrew-w atebee commented ·
Thank you.
Alex Pescaru avatar image
Alex Pescaru answered ·
Considering the fact that the immersion element is just a resistive load and don't cares if it's powered on AC or DC, can't you try to experiment and connect the PV string - correctly sized for the heater element's voltage - directly onto the heater element?
No loss in conversions, storage, etc... Of course not always the ideal maximum power point either, but who cares, you only heat water... :-))
MPPT Product Page
MPPT Error codes
