Hi all,
Need some help here to see if it is possible to use just 1x MPPT 75/15 to have two different load profiles? The application is 1) Light that runs dusk to dawn 2)wifi system that runs 24/7.
Thanks in advance for your help
Hi all,
Only 1 load profile can run at a time, since there's only a single load output.
Personally would recommend using the inbuilt load output to run your dusk-to-dawn light, and use a Smart BatteryProtect directly off the battery bank to run your 24/7 wifi system.
100 People are following this question.
