ryang1979 avatar image
ryang1979 asked
How do I charge with CCGX off and batteries flat?
Hypothetical as it hasn’t happened yet, BUT IT WILL so I am being prepared.
i have a Multiplus 24/3000 CC GX mppts battery monitor and custom lithium pack.
in the past when the battery goes flat I just pop outside, fire up the genie and the charger automatically starts .
however, with the CC GX controlling things, and it bring off, whats going to happen?
do I manually flip the Multiplus to charger mode? Will it respond to this And charge? Do I need to disconnect from the CC GX ?
is there a magically sequence to get it going to charge?
just trying to prepare for the inevitable.
thanks in advance
nickdb avatar image
nickdb answered ·
The inverter doesn't need a GX to black start, it is needed to avoid deadlocks, which is something else. The multi has a full config of its own. Properly configured it should recover and start working again when restart thresholds are met and there is a power source (genset) on AC1.
Ideally though, you want to be setting cut off values so you don't run a battery completely flat, that isn't great for any battery and avoids issues.
ryang1979 avatar image ryang1979 commented ·
Thanks for the reply.
So in effect when it detects the generator it will restart the multi
yes I have the bus set so it’s not dead flat, but in effect I will still loose the batteries and be blacked out.
