cdsolar avatar image
cdsolar asked
Multiplus II ignore AC input
In VEConfig I can tell the multiplus II to ignore AC Input until SOC is below a certain value. However, I can't tell it to again ignore AC input when SOC again reaches a particular value (after a recharge).
I can do this using assistants, but it would be nice to do so in the virtual switch in this same screen. Is there a reason you cannot ignore AC-in based on reaching a SOC, but only on voltage? Here is an image (there is no choice for SOC in the pull-down at the bottom):
Multiplus-II
