jimmyfal avatar image
jimmyfal asked
BMV-712 - accidentally enabled "DC Energy Meter" in Misc Settings
Setup:
345w solar
Victron - BMV-712
Victron MPPT 100/30 Solar Controller
Victron Non-Isolated DC to DC Charger
Battleborn 12v 100ah battery
Android App
Problem:
BMV-712 - In Misc Settings in the app, I accidentally changed setting from "Battery Monitor" to "DC Energy Meter" in Misc Settings because I got curious.
Now battery symbol flashes on display... there was no option to back out of this setting before it took hold, I was warned about need to be "wired" for this setting, or something to that effect. I immediately force quit the app before acknowledging "ok".
I then put the setting back to where it was "Battery Monitor".
Next thing I knew, there is a battery symbol flashing on the display, and I have no SOC %, just 3 horizontal lines.
What have I done? Should I not have done it? What do I do now?
Thanks, if you can.
JF
BMV Battery Monitor
kevgermany avatar image
kevgermany answered ·
Three lines for SOC is normally ok. Just means that it hasn't registered a full battery since installation or power on. You can go into battery settings and manually enter a nominal value. This will be the base for future readings until full charge is detected, when it will synch to 100%.
Suggest you check all the settings, especially battery.
