4711austria avatar image
4711austria asked
charger is not charging the battery ?
3x ESS, DVCC active, no BMS (Node-Red handles over battery infos).
ESS is working fine, charger is discharging the battery
but charging is not active any more.
which parameters (Mqtt) do show active/deactive? what can be switched to change the normal behavior?
Thx a lot!
Multiplus-IIcerbo gx
