Hello, I am monitoring my system on the VRM and found my Quattro is in 'Storage' mode. I can remotely interface on the CerboGX. How can I switch storage mode off ?
Do you have lead acid batteries? It does that after 24hours of being in float - and is a good thing in that case.
Storage mode is in the base programming, you would have to remote configure it and remove it as an option.
Hi ... our 12/120 5000 Quattro is supporting 3x 270 Ah Battleborn LiFePO4 array.
Is the 'remote configure' you mentioned an option from the CerboGX or another interface, directly to the Quattro?
84 People are following this question.
