astrayan avatar image
astrayan asked
Can MPPT 150/45 be wired to a 48V water heater element?
Now that Chinese are dumping high quality panels, it's a good time to convert my 300L solar hot water heater to a few panels.
Choices are:
4x Trina Vertex S+ 440W - (44-55Voc) in parallel --> 36V element (1200W, 33A, 1.08ohm) heater element. Trina specs say Pmax is 44V, but it will end up being 37V in the hot weather. This 1200W solution is a bit slow, because each one-person shower is 2kwh. However, it's also likely to deliver 40V in winter (1450W). And if it doesn't I can add another panel.
5x Trina 440W (ditto) in parallel --> 48V element (1500W, 31A, 1.5ohm). The panels probably wont make it to 48V, even lightly loaded. Probably 40V -> Yield 1248W
4x Trina 440W in a 2x2 configuration, into a Victron MPPT 150/45 or 150/70 --> 48V element (31A)
Plasmatronics PLW, which is specially designed for 48V, but costs $1400
There are also dangerous HVDC methods, like 4 in series (Pmax 160V). This into 240V 3600W element would yield 1500-1800W. Would also go into MPPT 250/70 for house battery. Rural fire brigades don't like 200VDC.
A complication in Australia is that amateurs are not supposed to work above 60VDC, option 1 - 36V element looks good, even if I'm overloading it a bit.
I can't find a 48V MPPT with a 40A load, because Victron has monopolized DC MPPT, but has no LOAD on any of the controllers. I suspect that if you output directly to a linear element, the impedance mismatch at low voltage may put extra burden on the MPPT, and also the MPPT may get confused with low voltages, since it expects a battery. But on the other hand, it may work, and only cost $200. I also want to use the 4-5 panels for cloudy weather charging my house battery.
MPPT Controllers
snoobler avatar image
snoobler answered ·
Once set to an operating voltage, Victron MPPT do not require a battery and can be powered directly by the PV and power a resistive load without issue.
It is not officially supported to use an MPPT as a power supply, it is generally not used for high power devices like that and there are considerations that will affect the mppt generating stable power (power point tracking etc). This is stated in the manual as well. But like all things it is done, but terms and conditions apply.
astrayan avatar image astrayan commented ·
Thanks, Snoobler
