I've seen this question asked a few times.
The measurement at the battery terminal is about .3 volt lower than what my easysolar says.
I Have used a few different multimeters and they read the same.
Cable length is about 800mm and have attached a pic
Should I be compensating the voltage settings for this difference? And take true readings from the battery terminals as opposed to relying on the inverter?
