whitworth-marine avatar image
whitworth-marine asked
IP43 vs IP22 Charger
Now that the IP22 has VE Smart:
So if water ingress is not a concern and i do not need remote control or control a relay, how to choose between a same featured IP43 or IP22 charger say a 12V 30A 3 output unit. A quick dive into demo mode finds that programming ability is essentially the same, so does it just come down to whether one wants natural or fan cooling?
charger
Alexandra avatar image
Alexandra answered ·
@Whitworth Marine
Yep, it comes down to install conditions and needs/wants. (And often what is cheaper than suits the need).
They will both charge the batteries connected.
I am sure you have looked at the tech specs for the IP22 and the IP43.
Gregor Kopka avatar image
Gregor Kopka answered ·
Also there is the detail that the IP43 charger is available in a 120-240V version, which is more flexible when having to deal with mains power in areas where supply voltage level fluctuates.
Chargers.
