These 4 parts were delivered with my Multiplus 12/800/35 inverter charger. Could anyone help me identify what they are for?
I believe the 4th item is the temperature sensor cable, but I have no clue about 1-3.
Thanks!
Thanks!
1) There are the two Wieland plus, one for AC-IN and one for AC-OUT
2) This is the spade connector for connecting to the trickle charger output for a starter battery for instance.
3) This is the securing clamp for the Wieland AC plugs. It goes between the two plugs and then there is a screw hole at the top of this clamp to help prevent the plugs from being pulled out.
4) As you suspected, this is indeed the temperature sensor.
8 People are following this question.
