harry4516 avatar image
harry4516 asked
MPPT 100/20 shuts OFF on a sunny day
I have a couple of charge controllers, MPPT 250/100, 250/70, 150/35 and three MPPT 100/20.
The MPPTs 100/20 sometimes shuts off during normal operation, see this picrture:
at 14:00 you see the graph going to 0, then it stays at 0 to 5 watts. When I disconnect the solar panels, and reconnect it, then it works again as expected. I did that so minutes later, when the graph goes up to the normal power.
I know three people in our city having exactly the same problem, also with MPPT 100/20.
All my three MPPT 100/20 are BMS controlled via Cerbo. So if any shut-off condition occurs, I would expect that all charge controller are deactivated by the Cerbo, but it is only one or the other, randomly.
Since I am not alone with this issue, I wonder what could be the reason for this shut-off, and why do I have to disconnect/reconnect the solar panel to get it working again?
It only happens with the MPPT 100/20, not with the others, and there is no error message recorded.
MPPT ControllersMPPT SmartSolar
