Which of the ports on Connection M do I use for the remote switch wiring? Aux 1 + and Aux 1 -? How exactly do I wire the remote switch? Thanks.
What specific model of MultiPlus-II? The manual is usually pretty clear, but to assist further we need to know what you're working with.
Thanks Justin. It’s actually the Multiplus 12/2000/80
The new style or the old MultiPlus Compact? If the new style then you'd be looking at Connection H, which is just a remote jumper plug - there's a black jumper wire, interrupt continuity (or remove the plug) to turn unit off.
https://www.victronenergy.com/media/pg/MultiPlus_2kVA_120V/en/appendix.html
If the old style MultiPlus Compact, then you're probably looking at Connector L listed in Appendix A, with instructions: https://www.victronenergy.com/upload/documents/Manual-MultiPlus-Compact-2000-120V-REV-09-EN.pdf
103 People are following this question.
