windowexperts avatar image
windowexperts asked
Do I keep my 12v house battery to start the generator?
I have a 24v system powering a Victron Inverter. I am planning on putting an Orion 24v to 12v converter.
Will I need to keep at least one 12v battery to power the DC items on my motorhome?
If not, what would I use to start the generator? Would I wire it to the chasis batteries instead?
What's the best practice for this?
Lastly, if I'm keeping a 12v battery in place, what would you recommend I use?
starter battery
kevgermany avatar image
kevgermany answered ·
Your generator should have its own internal battery, so no need for an external battery.
If you're going to be using the generator rarely there's a risk of its battery running down. Setting the Orion converter to float voltage and connecting the generator to that will prevent it. Usual float voltage for 12V batteries is 13.6/13.7V. Your 12V systems will be fine on this.
