gary bastin avatar image
gary bastin asked
how to clear "GX Error #48 DVCC with incompatible firmware: Warning"
So, i know my system has this issue, and i cannot clear or fix it due to older 19 chipset inverters. I cant afford to change them, and the system works perfectly using the BMS on the Pylontech batteries, has been for over a year now.
The pylontech batteries force DVCC on, so i have no choice.
I also use 6 of the older blue solar chargers which i love.
But the constant red alarm across the top of dashboard is really annoying.
Is there a way of permanently stopping this alarm or making the system ignore it ? Ive looked through all the alarm rules and cant see a way.
Here is my system, All firmware is latest version available.
2 x 5kva multiplus in parallel (19 chipset)
1 x 3kva 24v multiplus (emergency backup)
6 x 150/70 mppt VeCan 250kbs
1 x 150/100 smart charger
1 x smartshunt wind turbine
Cerbo GX
10 X PYLON TECH 2.5kwh BMS on VeCan 500kbs
10kva genset
52 panels 7arrays
DVCC
nb-np avatar image nb-np commented ·
Same issue.
