When the multiplus II 24 3000va, and it is connected to shore power, how much power does it use?
The idle power in the spec sheet should give you an approximation but I believe this is the DC power while inverting with no AC loads. AC input power with no loads and not charging the battery will likely be a bit higher.
104 People are following this question.
