anton-kalachev avatar image
anton-kalachev asked
3 wire 240V appliance in US MultiPlus-II 2x 120V
Could not find an answer to this anywhere. I have a 240V sauna heater that has 3 wires (2 hots and ground). It is in US. AC In is 240v. I am planning to connect AC Out 2 on MultiPlus-II 2x 120V and use L1 and L2 without neutral connected. Is it a proper setup?
Two follow up questions:
- If AC is available, will the multiplus use the battery at all on AC Out 2 with ESS enabled?
- I assume that ground on multiplus body should always be connected even if AC In has ground. Is it correct?
Appreciate all the guidance.
Multiplus-IIusa
