Hello, maybe this is a stupid question, but where can I find the second output of my multiplus 1600 to charge my starter battery. Thanks!
It depends which version you have, but the trickle charge connection location (if equipped) can be found in the appendix of the user and installation manual for your model. If you have the newer-style model it's here:
https://www.victronenergy.com/upload/documents/Manual-MultiPlus-1600VA-EN-NL-FR-DE-ES-IT.pdf
Thanks! I have the old style edition. And in that manual it says there is a second output. But the drawing is a bit unclear to me.
Oh, the old boxy one? That should be this photo then, looks like it'll be (as it usually is) just a little Faston terminal (otherwise known as a spade connector) on the left side. Worth noting that it's only a +ve connection on any of these, the assumption is that your starter battery and main battery bank share a common negative return path.
41 People are following this question.
