johnwater avatar image
johnwater asked
on a boat have one start, one house
confused on "midpoint" diagrams and just need a clarification please. is this wiring the same as batteries in Series? I have 2 -12 volt batteries used to create 24volts and want to monitor current going out when using troll motor.and each battery is charged back to full when I come back from fishing and connect to charger/shore power.or should I see a different diagram? thanks jphn
voltage drop
klim8skeptic avatar image
klim8skeptic answered ·
@Johnwater Where does the "one house" battery fit into your post?
Re mid point monitoring of your troll batteries, check out diagram 7 of the Quick install guide.
johnwater answered ·
sorry didnt mean to put this in the one house thread.looking to connect my 2 12 volt batteries for my troll motor on boat, just need a diagram or a description of hook up to smart shunt.
John
Negative goes to the load side of the shunt. If the aux connection on the shunt isn't being used, you can use it to monitor the voltage .
