Defever49 Reisen avatar image
Defever49 Reisen asked
Quattro 3kW shut down when connected to grid
When my 3kW Quattro is in inverter mode and grid at the same time is connected it happens that the Quattro shuts down and gives a message for overload. As soon the Quattro is set to charge only it works normally.
Every time the Quattro is set to inverter mode it tries to feed current to grid, just as a spike, and the “drossel sound” is heared as a shot. This happens approximately once an hour, and are seen as negative spikes in the VRM advanced picture. The setting for operation is: "Country/grid code standard: None: (feeding energy from DC to grid not allowed)"
Paul B avatar image
Paul B answered ·
Hi Is the unit on the latest Fw and some more details as to how its been setup and whats is CPU a 19 series or a 26 series
Ie are you using assistants and the ess etc etc
