danielgee avatar image
danielgee asked
Smart Solar MPPT 100/30 max panels
I just recently bought a Victron MPPT 100/30. Currently I have a (1)Go Power 200W panel with these specs:
Solar cell type Monocrystalline
Output power
200 W
Rated current
9.62 A
Rated DC voltage
20.8 V
Open-circuit voltage 24.3 V
and one of these(1( Go Power Panels:
Output power
100 W
Rated current
5.43 A
Rated DC voltage
18.4 V
Open-circuit voltage 22.6 V
I would like to add one or two more of the 200W version above. Will I be able to use my current controller that I just purchased this past summer? I suppose I should have asked this first before buying the 100/30. It would be a bummer having to buy another controller. If I have to, I'll get rid of the 100W one and just run two more of the 200W version if it means I can keep my current MPPT controller .
MPPT Controllers
It's not recommended to connect different panels together to one MPPT.
You should have one MPPT for each panel type.
danielgee answered ·
According to Go Power's website, the two panels I have are compatible with each other. Are they not when using this MPPT controller? I had a Go Power PWM before replacing it with the Victron 100/30.
snoobler avatar image
snoobler answered ·
Panels can be safely mixed and matched following two simple rules:
  1. Panels in parallel need to have very similar Vmp - typically within about 10%.
  2. Panels in series will operate at the current of the LOWEST rated panel.
You have two "12V" panels with Vmp 18.4 and 20.8. That's about 11.5% difference. They are not a great match.
If you put them in parallel the total array will take a performance penalty as much as the difference, 11.5%
If you put them in series, the 5.43A panel will force the 9.62A panel to work at 5.43A thus killing nearly 50% of its output.
If you place 3 200W in parallel with the 100W, the total array will suffer as much as 11.5% performance penalty. Each panel will require its own fuse or breaker (3 or more in parallel require this).
Partial shading performance may be notably impacted.
4 comments
danielgee avatar image danielgee commented ·
What about getting rid of the 100W panel and just getting two more of the 200W. Will my current MPPT 30/100 be ok for this?
snoobler avatar image snoobler danielgee commented ·
Yes. Either in 3P or 3S configuration. If 12V battery (max output of about 435W), you will be over-paneled, but are within limits.
danielgee avatar image danielgee snoobler commented ·
Thank You for your help. I think I will buy two more of the 200W for a total of 3 and remove the 100W. Keeping my Victron 100/30.
Good plan
bladerunnervf avatar image
bladerunnervf answered ·
See
https://www.victronenergy.com/mppt-calculator
Enter your panel specs and away you go
