loujohng avatar image
loujohng asked
Best setup for external 12v A/C using Truck 24v system?
Hi to everyone. Any help appreciated.
@Michelle Konzack
I'm trying to build a system for my truck which did not come with an air condition unit. The truck has a 24v 90 amp alternator. The AC unit that I have uses 12v; the compressor can draw up to 70 amps. I am trying to get the best setup possible in order to accomplish this.
I have an Orion Smart Charger 24/12 20 amps, and a DC to DC Converter (Higher Power) 24/12 70 amps. I'm exploring the two setups based on the images below. Any suggestions on how I can make this setup better is appreciated.
I am considering getting another converter. I assume this would produce 140 amps possibly and I wouldn't necessarily need that much. Lastly fuses would be installed near sources/inputs.
Setup 1
Setup 2
Setup 3
Orion DC-DC Converters not smart
4 comments
Couple of comments
Charge rate to aircon system is very low, max only 20A. You'll need to run the engine for about 3 times as long as the aircon runs.
Likely that the batteries for aircon are undersized for such a large continuous load. You need to check battery specs, but unless they're lithium, you'll get nowhere near the rated capacity due to the high current. Heat will be another issue.
loujohng avatar image loujohng kevgermany ♦♦ commented ·
Truly appreciated. I had to edit the image. I'm using LifePO4 Lithium batteries to power the AC unit.
Can you say what is the best charge rate for 12v 100ah batteries? Anyone?
kevgermany avatar image kevgermany ♦♦ loujohng commented ·
Varies. You have to check the manufacturer's specs.
