wice22888 avatar image
wice22888 asked
Wiring 2 Different size MPPT Controllers
Hi all
I have 2 Charge controllers
1. Victron Energy SmartSolar MPPT 75V 15 amp 12/24
2. Victron Energy SmartSolar MPPT 100V 20 amp 12/24-V
Do need to connect them to charge one battery.
What will be the best way to wire these controllers without buying some additional buck up solution?
MPPT Controllers
henrik avatar image
henrik answered ·
Connect them both directly to the battery
nickdb avatar image
nickdb answered ·
It is never a good idea to use a battery as a busbar, that is sloppy wiring and opens you to issues.
A good source of info is the wiring guide https://www.victronenergy.com/upload/documents/The_Wiring_Unlimited_book/43562-Wiring_Unlimited-pdf-en.pdf
Connect them via a bus bar and be sure to independently fuse the connections.
You will want to use smart networking, unless you have a GX, to help coordinate charging.
This is all documented in the relevant manuals.
