itrepac avatar image
itrepac asked
MQTT topic for Self-consumption from battery - All system vs Only Critical loads
In case of Inverter AC output in use parameter is Active in ESS setup in GX device, then there is possibility (according to 4.3.4. Self-consumption from battery ) to set-up ESS only to use battery power for essential loads. It also allows battery banks to be sized to get critical loads through the night without the battery being discharged into the non-essential loads.
Does exist possibility (or plan ) to make this setting by MQTT topic? Or it will remain "as is" due to dependency on other parameter (AC output in use)?
Thank you in advance.
P.S. Could it be that my approach is wrong, but I want to based on some circumstances decide to use battery discharge even for All system load.
MQTTess settingsbmv power consumption
Victron MQTT readme
