On my boat I have a BlueSolar MPPT and solar panels - also a Quattro with shore power and genny etc. There is a BMV too.
The BlueSolar MPPT detects battery voltage "in the morning" to adjust the maximum absorption time. Great when I am off the boat as this maintains the house batteries. However what is the situation when I am onboard? When it detects the voltage I might be charging with the Quattro or even drawing a short heavy load from the batteries.
1. Exactly when is "in the morning"?
2. Can the MPPT reassess battery voltage at another time to adjust maximum absorption times?
A typical scenario for me when at anchor is to run the genny in the morning to do bulk charging of the batteries and then to switch over to the solar panels to do the absorption and float stages. For that to work I need to control when the MPPT starts its daily sequence.
I am thinking of adding a Venus GX to the above โฆ would that help control this? Can it take battery state from the BMV?
